I just purchased a 2011 GMC Sierra SLE Z71 4x4 5.3L with the upgraded Towing package, HD package and rear axle ... Going to be towing my 4.5 - 5K 24' travel trailer equipped with WD hitch and Tekonsha P3 brake controller.
My main question for when towing is I know I need to have trailer button on, but what about the tranny?
Should I keep it in regular "D" (Drive) and let the 5.3L Active Fuel Management switch back and forth from V8 to V4, or should I have it in automatic / manual 6-speed and keep it say on M5 when towing so it doesn't use AFM and I get the full V8 power at all times?
Also should I leave the display on transmittion temperature? I figure the tranny will be doing some work when towing this trailer 7K+ heights and many hills straight up ... should I monitor this as well? and if so what is the max temp the tranny should be at and if it goes over should I pull over and let it cool down a bit?
Just want to make sure I know everything there is to know about my truck when towing a trailer and what settings I should keep everything on.
Anything else I should know or be conscious of when towing a trailer?
Thanks so much for any information and help you can provide on this subject.
My tt is close to 8k loaded. Usually in D with tow haul on. If it's a nice calm day and flat land I'll turn the tow off. And I leave the trans temp on just to monitor. The max temp I've seen is 204 GM says you're safe to 265.
1) I would just keep the trailer button on and let the truck do the shifting.
2) You can keep the trans temp on but you shouldn't have any problems. I would only worry if temps starting getting north of 220 but mine hasn't gone past 200. Someone else might have a different opinion on that.
3) Sure you already know this but make sure you are aware of how to fully operate your brake controller
4) Have fun!
When my wife & I just PCS'd to Washington from Oklahoma my enclosed trailer weighed 10,000lbs and the truck was full also. GCWR was 15,900 without myself and a couple of bags. I left the transmission in "D" & used "tow/haul" for 95% of the drive. When I did deselect "tow/haul" it was really flat and I was trying to up my MPG's by letting it stay in 6th gear.
If you choose to run it without "tow/haul" and it's shifting a lot in & out of gears while cruising then I would watch your transmission temp. If it's rising then engage "tow/haul" to help prevent the extra shifting since that's what causes the rise in tranny temps. I also looked for a max transmission temp & never found one. The highest I've ever had mine was 201 and that was at the dragstrip on a 100 degree plus day after making almost a dozen passes, it showed no ill effects. When towing it's never got that high (I want to say 170's/180's I think) Using "tow/haul" will also help when going downhill. It will downshift to help slow you down and in turn keep your brakes cooler.
Same here. I towed alittle over 8000lb T.T. on my old 2011 1500 with the same set-up as the O.P. I kept it in drive with tow haul enguaged all the time. You use alittle more fuel, but it keeps your tranny from excessive shifting looking for the right gear on hills and such.
Shouldn't have any problems with the tranny temp. I never once got my temp over 210 and that was hauling on heavy T.T.
Just keep the tow/ haul button on all the time when pulling tt, don't be hesitant to give her the gas to get up the hill, it will be ok. I just got back from tt pull with my 5.3, in foothills of mountains we did see 4,000rpms a couple times but it was 2,700 rpm's or less most of the time. And watch out for the other idiots on the road!
P.S. my tt is 7,800lb dry weight....I have hd tow package also...never saw more than 180* on tranny temp....
4H shouldn't be needed unless your on snow/ice covered roads, I've never pulled a tt through snow ice roads, someone else will have to comment on that for you...
So when towing on a very steep downhill (there is a few mile section that's called the 4-lane here that has a very steep grade) should I run the Manual and keep it in a low gear to help with braking?
i would use built in grade breaking. so the way to do that would be to set it to tow haul in drive. then set cruse control to like 35 or 45 or whatever you feel comfortable with. and let the truck figure it out. if you feel like it isnt doing enough you can put it in manual at any time and then lower the gear accordingly.
Stick it in D; tow\haul in the city and hills; watch for any trans temps past 200 or engine temps past 210... pretty simple. Don't forget to check your mirrors and other gauges every 30 seconds or so. Other then that, enjoy the ride! Towing a big trailer will become 2nd nature, so don't forget to have fun on the trip too. You'll be fine
IMO and what I do...
Its a light trailer @4.5-5K LBS Would just watch the trans temp and leave it in drive. Dont need the tow/haul on unless you need it for hills and such.
Enjoy the trip..
