My drive belt is squeaking like a squeak squeak squeak noise... it squeaks once per revolution. Am I right in thinking that the most likely culprit is the belt tensioner pulley bearings, and that if repacking them doesn't fix it then the next most likly cause is the water pump?
Sounds right on to me. My old truck did this, too. Usually when it was cooler, or damp outside. Once it warmed up, it would stop.
I am not sure how serviceable the tensioner pulley is. Let us know if you do the repair, and how it works. This would be very useful info.
First thing to check is how old the belt is. I dont know if you can repack the bearing in those. I know on my old cherokee xj you could. Would like to know if it can be done also.
The bearing in the tensioner assembly is a sealed bearing assembly, meaning no way to pack with grease. If the belt checks out OK, you will then need to replace the tensioner. Dependinng upon availablity, you my need whole assembly, or could get pulley with bearing pressed into it.
ive replaced them on an older C/k and on my saturn..sometimes u need to use the stethiscope to find out exactly which one it is
