1 - 6 of 6 Posts
My alternator had been replaced 4 or 5 years ago because the bearings let loose in the original. I replaced it with a cheap reman because that was what I could get right at that moment. It served longer than I thought it might, but is starting to complain now. The original was the 125amp Bosch. I just ordered a brand new GM (Delco I think) 145 from Rock. I have added an inverter for charging drill batteries, and a few other things so I figured I would up the amps since I had to replace it anyway. I looked at the belts and it shows the same size for all 3 alternator choices, but I thought I read the need to change belt size. Do I need to? Or just wait and see if there is enough play to get the belt on?
thanks.
1999 Silverado ECSB 6.0
No you do not need to change the belt size that I am aware of.
Worst comes to worst you drive down to the store and buy one haha
The brown truck brought it in today. I waited until my grandson got home to install it. He is almost 3 and loves tools and working on the truck. It took about 20 minutes, mostly because I dropped the nut and had to get a magnet. Once he saw how cool that was he just HAD TO pick something up. So I let him pick up my 10mm socket, over and over again.
The dimming lights and a/c at idle problem is gone. I will probably throw this one up on the shelf as an emergency spare. Which means I’ll scrap it in 4 years after having moved it dozens of times.
1 - 6 of 6 Posts
