Decided to go ahead and install my differential drop. I refused to install a RC drop where they make you cut your cross member and use their skid plate. Found this one on eBay.
I first tried to install it with the RC lower leveling spacer and this happened. I tried to get ahead of the game before installing coil overs, and their description said it would with with 2-4in kits. But didn't specify top or bottom spacers.
I put it in my tool box and forgot about it until now.
Was an easy install. Took two hours by myself, doing one side at a time. All instructions tell you to remove the entire diff, no need for that. A long jigsaw blade and a file will do the trick to remove the fin
I had to file off a little edge on the back of the diff to completely clear the cross member. But there is clearance
I used some thick stainless washers to space the stock metal skid plate away from the diff. No loss in ground clearance.
Here is before and after once it's settled. Before the CV was at the same angle as the tie rod.
I would recommend this kit if you leveled your truck using coil overs, upper strut spacer, or 5100s. Cheap and easy way to get back some factory angles.
This is the kit
https://www.ebay.com/itm/141349204918
This is the kit
