Its the front passenger door and the trim does pop off but you have to remove the door panel to remove the interior handle because under the panel is a bolt or rivet holding the handle onWhich door? if its one of the front ones doesn't the interior handle trim pop off and then you have access to removing the handle assembly and replacing either that or the rod clips on the inside would be what you need to do.
