Well exhaust temps at the manifolds can reach around 1200⁰+ ideally lower though, especially on these motors lol. My duramax I've hit 1250⁰ on the dyno.
So in theory, a high temp paint like that should hold up. But it has a stainless heat shield that goes over it anyway. So I may just paint that black with some exhaust paint.
CLP is a gun cleaner. It's a oil like fluid that helps soften and remove carbon build up from firearms. But as it turns out it also works for exhaust carbon. Which makes sense because the two are very similar.
I got the turbo all rebuilt and dry fit. I just need to pop the front plate off the compressor side and seal it up, seal and install the compressor cover (after I paint it), and then install the whole thing onto the exhaust housing.
The waste gate will be modified a bit as far as mounting goes. I want to change it so I can manually adjust the PSI at which it opens.
The rebuild kit I got was a bit confusing for two reasons, one of which is the fact I took it apart over the summer and didn't remember exactly how it went back together, and two, it's for all the turbos, GM3 (this one), GM4, GM5, GM6, and GM8. So the seal rings didn't match up exactly. I did reuse one of the old ones. It should be OK, but if not, at least it's on the easier side to remove so I can be done on the truck if need be.
