Hello from the 49th state and thank you in advance for any suggestions for troubleshooting this frustrating issue as I am working in the dark as temps hover around zero.... :roll:
Pertinent Background Info: 2000 Sierra 4x4 1500 5.3 Vortec 200,000 plus org miles
Owner had a service engine light come on several months back but took no action. Light is still on.
Not owning a reader, no codes have been identified YET but will resolve this issue soon and update.
In the past 12 months owner had noticed intermittent slow starts and occasional flat or sluggish response upon acceleration.
Several weeks back truck suddenly will not start, and I am recruited to fix it!
Fuel pressure (zero), spark at all cylinders and lack of audible pump activation tests indicated faulty fuel pump.
Fuel pump was replaced w/ oem ACDelco and new 4 prong flat wiring connector that matched factory wiring was installed and verified correct orientation.
Oem fuel filter and fuel pressure regulator were also installed and verified no leaks and proper operation.
Now here is where the conundrum really begins.........
Ignition is turned on but not started. Proper fuel pressure is verified.
Truck starts right up and runs, maintaining proper fuel pressure.
I am thinking this is a done deal, wrap it up. Wrong. :evil: I try to restart it later and the truck won't start again.
So I check the obvious...all fuses and inspect the relay. Everything looks ok. Check ground on frame under bed where fuel pump ground wire and tank neck ground strap attach and they are fine.
I Jump terminals 30 to 87 while i have the ignition keyed and the pump fires right up.
I switch out the FP relay for one of the other 3 identical ones in the under hood fuse block.
( POSSIBLE CLUE?: owner mentioned a previous issue in last 12 months with some moisture getting into that under hood fuse block and having some possible corrosion build up...this seems to have resulted in the horn becoming stuck on until the relay was removed. It was later dried and connections cleaned off and relay reinstalled without further incident.)
With the swapped relay, the truck once again starts and runs fine, going on 10 mile test drive with no problem. Thinking problem solved,and I will replace the bad relay. Wrong again.
Fast forward a day. Truck starts fine and warms up for 5 minutes no problem. Step on gas, truck dies. Attempt to restart fails. Swapping relays with either of the remaining 2 good relays both fail. Again check all fuses....they are fine.
Test the FP relay connections in the under hood fuse box. Have constant power and ground to the 2 appropriate terminals. Test for 2 second prime when ignition is keyed shows that terminal is energizing properly.
When I remove the FP relay and jump terminals 30 and 87 the truck starts and runs fine.
So I know that has been pretty long winded but I have read a ton of threads and want to make sure I provide as much detailed info as I can.
Now I humbly ask for your knowledge and input to help make the proper and necessary repairs! What would cause this symptom? Truck starts and runs fine with fuel pump relay removed and jumper wire from terminal 30 to 87 but not with a know good FP relay installed. I tested the relays for click sound when power and ground applied to 30/86 and I get 0 Ohms on the multi meter when I probe 87 and 85
I plan to disconnect battery and remove the under hood fuse panel and inspect it.
I will be getting a hold of a code reader and posting those results.
I understand I also need to test the PCM and would appreciate any insight on that subject!
So based on all that, THANKS IN ADVANCE!!! for any suggestions and advice! Mahalos!
