1 - 5 of 5 Posts
Okay so my 2000 2500 Silverado single can 2wd 6.0 had an odd grinding sound from the front left tire. I thought it was the wheel bearing cause I did have a wobble from what I assumed was a bent rotor replaced whole hub. Started off pretty barely hearing it once replaced and then after about 50 miles it came back 100%. Not sure what it could be balljoints ain't great but they are still tight. I have no idea what it is. Can someone help?
That is pretty perplexing. Does it do it all the time? You replaced the rotor as well? Check your brakes to make sure they don't have any abnormally markings or gouges. The backing plate might also be touching the rotor.
1 - 5 of 5 Posts
