Hey folks, I'm new here.
So I just bought a 2004 Silverado 1500 5.3 Crew Cab Z71. 295,000 km on it.
As the title says, I'm having an issue where when the truck is running the horn will not stop blaring if I Honk it even a tiny bit. However, if the truck is not running, it usually only honks as long as I hold the horn in.
I already pulled the airbag off and checked the switch contacts, swapped the horn relay, swapped the horn fuse under the hood...
I'm pretty stumped on this one. Anyone else have the same problem?
The only aftermarket items I know about on the truck are a front and rear dash cam setup, and an aftermarket remote starter.
So, could this be an issue with the actual horn? Or would it be a wiring issue? I'm thinking a ground... but where? Or would it have a correlation to the aftermarket components I mentioned?
Any help will be greatly appreciated!
Thanks!
Thanks!
