Right. Thats right.Did you not say 85 on the horn relay to ground is zero ohms? If 86 has 12 volts, and 85 is connected to ground, then your relay will change states.
That's what I'm really wanting to find out. If I unplug all the connectors from the BCM except that one, it honks and lights come one. So the issue is isolated to that connector.It's the BCM thats causing it for sure. The BCM has your alarm system. 85 from your relay splits. One wire to the horn switch the other to the BCM. Now is the BCM bad, or are you in some weird state i know nothing about?
Not sure, someone here may let you know if the BCM can be swapped. I don't know what security problem will arise.Would it be damaging to another vehicle to plug my BCM into it to see if the problem is replicated?
Would need programming right?Swapping BCMs would do nothing because the security mode will activate in the other truck.
