1 - 5 of 5 Posts
05 Silverado
Hi all,
Recently purchased an 05 silverado that has a minor coolant leak coming from what looks like a high pressure line right above the lower coolant hose. I am having a hard time finding the part number for this hose to order a replacement. In the picture it’s the dark hose that looks wet. Any help is appreciated.
Shoe Motor vehicle Automotive tire Automotive design Automotive lighting
Yes... transmission line/hose. You can cut the factory aluminum crimp ferule off on both ends and replace the hose with transmission cooler hose from a auto parts store.
Slip the new hose on 1 side first with 4 clamps loose then use 2 full stainless steel worm gear clamps on each end spacing them at least 1/2 inch apart or a bit more. Tighten them down pretty good but watch out you don't strip them out. Use hand tools only on the clamps.
05 Silverado
Thank you for the replies. Is the hose where it normally leaks from? In this case it appears to be leaking from where the line inserts into the radiator. I guess I’ll need to take it out and check.
Normally, it leaks at the hose crimp. I say clean the pipe area at the radiator and check it after a few days of driving to see if it is leaking there. May even take longer to appear as this is usually just a small seepage. Free and easy test.
1 - 5 of 5 Posts
