Hello all,
New to the forum and already a big fan after reading through a lot of info. Here's the issue that has brought me here...
2007 Silverado 5.3L, 140k miles. Recently got the check engine light which was the result of the familiar P0121 code for throttle position sensor. As I've read, it was most likely the result of the throttle body being dirty (which it was extremely). I followed the how-to tips found here and cleaned it last week. Since then, I've got new issues. As expected after cleaning, I had some high idling, but that has mostly resolved itself. However, when it is idling normally, put it in gear and it rolls slowly forward like normal for about 10 feet then takes off. RPMs climb to 1200 or so and speed climbs enough to shift into 2nd without touching the gas. When slowly accelerating or holding speed up a small hill with the throttle slightly depressed (around 1200-1300 RPM) it hesitates or stutters. If I accelerate faster, it acts normal. When slowing to a stop, the RPMs stay around 1100 until coming to a full stop, then slowly come down to 600ish. Pull away from the stop sign and it takes off again. It has not thrown another code since cleaning.
I'm leaning towards a faulty throttle position sensor. Any thoughts?
