1 - 7 of 7 Posts
Last year I blew the rear in my truck and went with a 3.73 gear setup. I never changed over the front gears to match so I'm not able to use my 4x4. What do I need exactly to change out the front gears? Is it just a 3.73 ring and pinion?
Unless there's something really special about your truck, it's way cheaper (vs paying someone to swap the gears) and WAY WAY easier (vs doing it yourself) to just swap the whole diff with one that has the right ratio... Find some parting out their truck, or even from a junkyard and do the swap.
I have a moderately built engine in her, the rear I put in is a Mosier posi 3.73 track setup. I rather new parts rather than used stuff. I spent around $2200 on parts for the rear end, I have no problem doing the work myself.
Ring, pinion and install kit. Just like you needed for the rear.
I like your logic OP! Hard to go wrong with new stuff, long as you can set it up properly, and sounds like you can.
If you've got the tools to do it, go for it... From reading through the process for the front diff in my '04 Sierra, it takes a bunch of more specialized tools to do compared with doing it for the rear diff (and some luck, as the driver's side stub axle doesn't always come out of the diff, and you have to cut it off).
Maybe subscribe to the full-service manual for your truck, and check out the rebuild procedure that GM has for it.
And if you do the job, I would suggest going all-in, and replace all the bearings/bushings/seals.
I dont know what year model you have but if its a 07-13 then check out the link in my signature and scroll down to step 20 and take a look at the front document. It walks you through a lot of it.
1 - 7 of 7 Posts
