Hi All,
I have beed fixing some of the plastic parts that break over time and this past weekend it was timeto replace the exterior door handles.
I ordered Doorman replacement handles for both front doors.
The drivers doorhandle went in with no issues.
The passenger door handlewent failry well and opened and closed nicely until...
So here is where I have run into trouble. I functioned the doors probably 5-10 each with no issue.
I cleaned up the truck, started it up, backed it out of the garage and moved it to it's regular parking spot in our yard.
As a sannity check, I got out of the truck and tried the drivers door again. No issues.
I walked around to the passenger side and tried to open the door. The door will not open.
Initially I though I had forgotten to unlock it, so I hit the key fob, and tried the door again. Nothing.
I went back to the drivers door and hit the unlock switch, then tried the passenger door again. Nothing.
I climbed into the truck from the driver side, and tried the interior passenger door handle. The door did not open.
I pulled the the lock up and down to see if that was causing the problem without success.
So in between the initial door functioning that went very well, unitl this point was, is that I started the truck and electrical power was introduced into the system.
Besides completely destroying the interior door panels to get into the door, any thoughts on what part of the elctrical system that may be causing the door to remain locked?
Thank you,
Kelly
Thank you,
Kelly
