Thank you I will check this out I looked in my owners manual I could not find anything. But I definitely have an option because I have a forward-looking camera if I drift out of lane putting my blinker on the alarm goes off and beeps at me. And I definitely have the Ford collision I have the button on the steering wheel and when I am far away from the car there’s nothing on the dash when I get closer to a car turns green as I get even closer it turns yellow And then when I get real close it turns red the warning alarm goes off and the lights on the dasAnd then when I get real close it turns red the warning alarm goes off and the three lights on the dash I’ve shine onto the windshield flash so I am getting all the warnings and everything is working correctly except for the fact that the seat just never vibrates
You must have the option and it must be set for beeps instead of alert seat.
(I don't believe there is a way to have it do both)
2014 1500 Sierra manual, in driver assistance systems section
Lane Departure Warning (LDW)
If equipped, LDW may help avoid crashes due to unintentional lane departures.
It may provide a warning if the vehicle is crossing a detected lane marking without using a turn signal in the lane departure direction.
LDW uses a camera sensor to detect the lane markings.
It only operates at speeds of 56 km/h (35 mph) or greater.
When the vehicle crosses a detected lane marking, the LDW indicator will flash and
either three beeps will be sounded from the left or right side, or three Safety Alert Seat pulses will occur on the left or right side of the seat, depending on the lane departure direction.
LDW will not warn if the turn signal is on in the departure direction, or if a sharp maneuver is made.
How the System Works
The LDW camera sensor is on the windshield ahead of the rearview mirror.
To turn LDW on and off, press switch on the center stack. The control indicator will light when LDW is on.
When the vehicle is started, the LDW indicator on the instrument cluster will come on briefly.
If LDW is on, the LDW indicator will appear green if the system detects a left or right lane marking while the vehicle is traveling at 56 km/h (35 mph) or greater. If the vehicle crosses a detected lane marking without using the turn signal in the lane departure direction, this indicator will change to amber and flash. In addition, three beeps will be sounded from the left or right side, or the Safety Alert Seat will pulse three times on either the left or right side of the seat, depending
When the System Does Not Seem to Work Properly
If the LDW symbol does not appear when the system is on and the vehicle is traveling at least 56 km/h
(35 mph):
. The lane markings on the road may not be seen.
. The camera sensor may be blocked by dirt, snow, or ice.
. The windshield may be damaged.
. The weather may be limiting visibility.
This is normal operation; the vehicle does not need service. Clean the windshield.
Lane markings may not be detected on curves, highway exit ramps,
or hills; or due to poor visibility.
If the LDW camera system does not seem to operate properly, cleaning the outside of the windshield in front of the camera sensor may correct the issue.
LDW warnings may occur due to tar marks, shadows, cracks in the road, or other road imperfections. This is normal system operation; the vehicle does not need service.
AND IN THE VEHICLE PERSONALIZATION SECTION
Uplevel Radio Audio System Controls
1. Press the desired feature to display a list of available options.
2. Press to select the desired feature setting.
3. Press BACK arrow on the faceplate or screen button to return to the previous menu or exit.
Turn the vehicle to ON/RUN to access the Settings menu,
then select SETTINGS from the Home page on the infotainment system display
and on pg 5-47 (still in personalization)
Alert Type
This feature will set crash alerts to beeps or seat vibrations.
This setting affects all crash alerts including Forward Collision, Lane Departure Warning, and Parking Assist alerts.
Select Beeps or Safety Alert Seat.
