Hey All, Long time lurker, first time posting. I have a 2014 Silverado 1500 Z71 5.3 4x4 3.42 with towing package. Just passed 42K miles, and wanted to change out the factory fluids before winter.
I successfully changed the fluid in my front and rear differentials and the fluid in the transfer case a couple weeks ago.Using all Amsoil products. I wanted to do the transmission as well, but haven't seen the details for a 2014 posted anywhere. I want to do a full "flush" by disconnecting the return from the cooler, but had a couple questions.
1. I've read there is a thermostat controlling flow to the transmission cooler. What temperature is the bypass set to? Is there anyway to override it for service purposes to? If not, once the pan has been dropped, filter replaced, and new fluid added, how do you heat is up to open the bypass....hairdryer?
2. I went out and took a look at the line, is the one I have circled is red the return to the transmission?
Thanks for any help
Thanks for any help
