1 - 7 of 7 Posts
Who’s had problems changing ball joints on a 2014 Chevy Silverado? ball joint won’t seat in spindle. Got cast iron LCA. It’s too cold for this lol tried the Moog and same thing I used k500245. There’s still ab an inch on the stud exposed on knuckle. Someone point me the right way.
Automotive side marker light Automotive parking light Tire Car Vehicle
· Supr Mod, AutoTech 🥇Mbr Extraord, 🏅TOTM SS-Guru
2015 High Country Duramax
Those are the wrong ball joints. It says on moogs website those are for aluminum control arms. The stamped steel and aluminum arms use a larger ball joint than the cast/forged arms.
· SS-Guru 🏅TOTM, HowTo Author,🥇Mbr Extraordinaire,
2010 GMC All Terrain 4x4 5.3 LC9 211k mi
Check RockAuto for part numbers that will fit. They show in the descriptions if it is for an aluminum or cast iron control arm. I really like the Mevotech TTX stuff when available.
Product Rectangle Purple Font Screenshot
The thing that confuses me is that those are splines on the part that presses into the knuckle itself. The one I took off was smooth and had to use a punch to get the lip up to press it out. Will that fit on my truck? I’m seriously confused on this. I got that part ordered from my oreillys and it’ll be here tomorrow. So if I have both cast iron LCA and knuckle that’ll work?
The replacement lower ball joints go in easier and use a spring clip to hold them in.
1 - 7 of 7 Posts
