Before posting this thread, I did search but found half completed/replied to posts about my current issue.
2014 with a 2016 front clip
Reconstructed title
Purchased over a 1 1/2 years ago without issues until now
Issue:
Power Steering Drive With Caution on the DIC. No power assist whatsoever.
Went to check the PSCM (power steering control module) because it is electronic assist not Hydraulic. Plug a little wet with fluids.
Looked up, Water pump leaking from the weep hole
Looked down, Transaxle leaking near the 4WDA (4 wheel drive actuator) that I replaced about a year ago and had no issues with since, but is now leaking in that area.
All this is close to and near the connection to the PSCM which leads me to believe the leak may have caused the issue, but not 100% sure!
Traction Control light on
Brake Light On
ABS light on
U0121 codes:
ECM (Engine Control Module) - Lost communication with the EBCM (Electronic Brake Control Module)
TCM (Transmission Control Module) - Lost communication with the EBCM (Electronic Brake Control Module)
Its going to the dealership on Feb 1st for diagnostic.
Was hoping someone might have gone through the same thing and found a fix for it. I dont think its the ground by the dash speaker. This just seems out of the blue and will more than likely cost a lot of money to diagnose and repair as small shops will not have the proper scan tools/programmers to properly fix this issue.
TIA!
Reconstructed title
Issue:
Brake Light On
ABS light on
U0121 codes:
TIA!
