Hi, thank you for taking the time to read this! The truck is a 2015 5.3l bone stock with 41k miles. I don't drive much. I received a CEL and code P0420. I reset it with a scanner and it comes back within 10 minutes of driving. I tried driving on the highway for an hour as well and then resetting since most of my driving is short trips. I have a scan tool from harbour freight and got the below readings. I was hoping someone might be able to help me decipher if its the cats or a sensor?
02B1S1 (v) .080 - .780 fluctuates
02B1S2 (v) .820 steady
02B2S1 (v) .085-.760 fluctuates
02B2S2 (v) .810 steady
I also did the self test option and received :
Catalyst Test Bank 1 catalyst DFCO exit test .091, min .50, max 4.0, STS Failed.
Catalyst Test Bank 2 catalyst DFCO exit test 1.117, min .350, max 4.0, STS OK
With these results would I be able to pinpoint the O2 sensor or if the catalytic converter is bad on bank 1? Ive tried reading through forums with this info, but not successful in finding out, usually just replacing a ton of parts. Thank you for any help.
-Kris
-Kris
