You can copy and paste it without using those buttons at the bottom. You can also drag and drop it right into the message as well.
Just got back from Ny, drove about 900 miles for break in. Got 32 mpg at 70 mph, and this with the 373 rear end. I am impressed. Curb weight is 5550 and payload is 1750. Payload is lower that I anticipated but is workable. Haven't had time to figure out how to post pictures yet.Post up a pic of that towing and load sticker in the door jamb when you can and of course, pics of the whole rig! Congratulations and good luck!
There will be a capacity label on the door post, with numbers specific to your trucks vin.I am trying to get my weight Distributing hitch set up and trying to figure out how much payload capacity I had left when I read this in the 2022 Silverado trailering guide.
Maximum Trailer Weight Rating This rating is determined by subtracting the tow vehicle’s weight (curb weight) from the Gross Combination Weight Rating (GCWR). Base vehicle (curb) weight plus 150 lbs. each for the driver and a front passenger is used, so additional passengers, equipment and cargo weight reduce this rating. This rating can be found on the Trailering Information Label located on the doorframe for Silverado 1500, Silverado 1500 LTD, Silverado HD, Suburban and Tahoe.
Am I reading this right? I looks like they are including 150 lbs for the driver and front passenger in the curb weight.
Below is a calculator for determing rpm's at a certain speed. I ran the numbers between the off road package and the max tow package with 22" tires and came up with this:Tonight, I just ordered a 2023 Sierra 1500 Double cab, with the new LZ0 3.0L diesel. I added the X31 off road package instead of the heavy duty trailer package. Our RV trailer is 3500#s, plus gear, and two dirt bikes in the bed. I want to be able to drive 72-75mph all day without killing the truck. Should I change my order, replacing the X31 off-road package for the Max towing package? The dealer told me it was only a gearing change in the rear end, no additional transmission or engine cooling, so I went with the off-road package and the duel speed trans with 4H & 4L. What do you think?
I made an excel spreadsheet for the different GM transmissions so we can play around with tire sizes and gearing and even takes into consideration the tread depth of the tire.Below is a calculator for determing rpm's at a certain speed. I ran the numbers between the off road package and the max tow package with 22" tires and came up with this:
X31 package has 3.23 gears, .64 with the transmission in 10th gear with 33" tall tires would get you 1473 rpms at 70 mph.
The max trailer package has 3.73 gears and that would net you at 1701 rpms at 70 mph.
Here is the calculator for you: Calculate RPM for Given Speed(MPH), Rear Gear Ratio, and Trans Gear Ratio.
I went with the max trailer package.
I understand, just posted a picture of mine and offered it to anyone as it is more accurate and one can see a whole lot more data. That one is off by nearly 50 rpms as it computes the tire as being perfectly round and some other things.swathdiver, great chart, however, I did click on my link and it took me to the calculator, as it is not an excel spreadsheet, just a link.
The 3.0 / 10 speed will happily run all day at 72 -75.Tonight, I just ordered a 2023 Sierra 1500 Double cab, with the new LZ0 3.0L diesel. I added the X31 off road package instead of the heavy duty trailer package. Our RV trailer is 3500#s, plus gear, and two dirt bikes in the bed. I want to be able to drive 72-75mph all day without killing the truck. Should I change my order, replacing the X31 off-road package for the Max towing package? The dealer told me it was only a gearing change in the rear end, no additional transmission or engine cooling, so I went with the off-road package and the duel speed trans with 4H & 4L. What do you think?
If you have received your vehicle, do you have any on the transfer case? Can you please post a picture of the transfer controls in the truck.I ordered a Chevy Lt crew cab 3.0 max trailering. The dealership said it was a special order only. The dealer called Tuesday said my truck was in the rail yard in Cincinnati, but didn't know when it would arrive at the dealership. I'm glad I ordered when I did as they have the 3.0 on constraint until the 2023 models, then it will have the LM0.
