Look at Demon Works video above, he listed how long a regen takes.Farmguy, using that gauge how long does a typical regen cycle last based on what you have observed?
Rasty, it's fairly easy. Just make sure you grab the latest firmware from banks ( I believe it's 1.24 but don't quote me on that). Once you do that and upgrade the firmware you will see an entry for the LM2 /0 3.0. Select that as your vehicle and then you can start editing the page layouts with the things you wish to monitor. Keep in mind you can have up to 8 items on each page and there are 5 pages. So you can effectively monitor 40 items but you have to changes pages to view each group of 8. You can also remove fields on a page which allows other fields to be bigger for easier viewing. For such a small package it's a pretty neat device. The one thing I would do is save your pages so if you ever have to reset the gauge you don't have to find all your pages and set them up all over again.Farm guy thanks for the explanation of what the windows in the iDash mean. Going out to put my iDash in now.
11 or 12 miles.Farmguy, using that gauge how long does a typical regen cycle last based on what you have observed?
Thanks for the tips. I got it in today. Biggest problem is sorting through all the parameters Banks has on it.Rasty, it's fairly easy. Just make sure you grab the latest firmware from banks ( I believe it's 1.24 but don't quote me on that). Once you do that and upgrade the firmware you will see an entry for the LM2 /0 3.0. Select that as your vehicle and then you can start editing the page layouts with the things you wish to monitor. Keep in mind you can have up to 8 items on each page and there are 5 pages. So you can effectively monitor 40 items but you have to changes pages to view each group of 8. You can also remove fields on a page which allows other fields to be bigger for easier viewing. For such a small package it's a pretty neat device. The one thing I would do is save your pages so if you ever have to reset the gauge you don't have to find all your pages and set them up all over again.
The fields for the regen stuff is under the emissions section of the menus.
The cool part is if you can get someone (HINT HINT Farmguy) to save their page set up and post it we can just import that and go from there. I still haven't gotten a chance to set mine up yet for the LZ0. The only field I defined was the regen field because work has been owing me lately. If I get a chance this weekend I will run through it and I will send you the set up.Thanks for the tips. I got it in today. Biggest problem is sorting through all the parameters Banks has on it.
Probably need to start a how to for the 3.0 and choices of parameters with the should haves. like the regen.
FARM: What I was referring to was, I have a data monster and a super gauge. Between the two I spent a ton of time setting up all the different fields on my prior Colorado diesel between the two gauges. I hadn't saved the page setups and one of my gauges needed to be factory reset because it locked up. Banks told me I was going to have to reset all the 40 fields on that gauge I had previously set up (lesson learned). So I started saving them to an SD card whenever I made changes. I would send them to other users so they didn't have to waste time reproducing the same settings. They could just simply import the saved pages I had already set up and then add or delete from there. I just haven't had the time yet to set up all the fields that I wish to monitor on my LZ0. So I was just being a lazy smart a$$ when I made that comment.Now you've got ME confused...I'm not sure what 'set-up' pages are being referred to.
First, there is not right/wrong set of things to monitor.
The thing is amazing and is capable for far more than what I do with it.
Any sensor data that is available is there because the truck us monitoring it anyway.
Us looking at stuff the truck doesn't already display is for our entertainment.
The truck is already monitoring and reacting to 'out of range' sensor information.
But, before mounting the unit, plug it into the OBD port an play with it. (might be easier to run it when in hand instead of mounted -- mine is suction cupped to top left hand corner of windshield)
Work thru the manual until getting the hang of working thru the menu's using the arrow keys.
There is a function that allows multiple pages to be loaded/saved -- so they can be recalled instead of re-selecting the codes.
I don't (haven't?) done that. As posted earlier, I do sometimes change the items displayed.
The items that can be displayed are grouped multiple ways in the menus, by type of information. Seems like many of them show up in more than one grouping.
They are listed using a 'name' rather that the address in the computer where the information is picked from.
So, the names with items shown in the idash pics that have been posted are the names that will be found in the menus. (if wanting to look at DEFLVL %, then select DEFLVL %).
The catch with all that is that sometimes the descriptions may not be what is expected. DPFSL and DPFRG might be examples of this.
You do have to select colours, and the number of data windows to display. etc. Doing this helps with learning to use the arrows to move through the menus.
As the pics show, I always use 8, which is the maximum. Manual (downloadable, but also supplied with the unit) shows what the different options look like.
Posters of other idash's often have a different window configuration.
Some have selected the data to be displayed as a bar graph.
The idash will, without changing anything, notify when the trucks fuel or def levels are low. Maybe other stuff too.
I don't believe, for one second, that one of these monitors is a 'must have' for a vehicle with stock programming. I think it is for 'entertainment'. I enjoy seeing how the truck programming reacts to various situations.
I ran 6.6's for about 14 years (LLY, LMM, LML and L5P)
When the LM2 came out I was reading a lot of stuff that I didn't think was correct - especially regarding emission. This was a second reason for the idash was to have 'data' to support my suspicions.
I seem to be rambling, so I'll stop for now.
I'm more than happy to respond to discussion / questions / hints.
