Hey all,
I've got a 2000 1500 with the manual 4wd lever on the floor and my 4wd doesn't work. When I put it in 4wd I get a light on the dash that shows 4wd but it isn't engaging. Doesn't make any funny sounds or anything. I read if the actuator is bad you won't get a 4wd light on the dash so i'm not sure if that rules out the actuator or not. What's the easiest way to check the actuator?
thanks
thanks
