I just found this site and registered and posted my first post to introduce myself. I look forward to learning and sharing on this site.
This post is about a problem I am having with my 4x4 and was hoping someone might be able to help me figure out the issue. I have a 2004 1500 Silverado Z71 with the 4 position electric button shift. I noticed that I had lost my 4x4 when I got stuck taking my boat out of the water on wet grass. I did some initial checking and found that the transfer case had no fluid in it. I filled it and then found a leak from the pump ring. The small hole was patched so I could determine if the transfer case was done. I lifted the vehicle off the ground and went through the positions for 4x4 and the wheels seemed to engage in every position, but the front wheels would turn faster than the rear wheels. The front wheels don't seem to grab when the truck is on the ground. Not sure where to look next. I also changed out the front axle actuator with another used one, but both seem to be working fine. I also tried to stop the front wheels from turning when they were engage off the ground, but I couldn't stop them. Is it normal for the front wheels to turn faster than the rear ones when 4x4 is engaged? Any tips would be much appreciated. I do realize that I will have to re-address the transfer case leak in the near future.
Thanks, Jim
Thanks, Jim
