Hi guys, newbie here with a question about 4x4 wheels. My 1999 steel wheels will fit on my 90 but my 90 stock wheels will not clear the calipers on the 99. Can I make them work with a spacer or am I S.O.L.
It was actually 2005 when they went to 17"rim as the smallest. So prior 2004 and older, you can use 16"SparkyJJO said:From 98 to 07 classic you needed a 16 inch minimum to clear the brakes. 2007 NNBS and up requires 17 inch minimum to clear the even larger brakes.
