I just recently bought a 93 1500 Silverado 4x4 and as I was driving it home a whine started to occur. It got louder as I drove on. I thought it was the power steering so I re routed the belt so it wouldn't run the pump and it still made it. Here is the list
1. It does it in drive or reverse in any gear
2. It does it a first start up but goes away until I put it in gear.
3. It stops when the torque converter locks to switch to a different gear then continues in that gear.
4. I changed the fluid and it smelled like a dead skunk, and lots of very fine metal shavings in the bottom of the oil pan. The fluid wasn't dark though.
5. The transmission otherwise does not slip or shift hard.
I took it to a transmission shop and they said my trans is burnt and it needs a rebuild which would cost upwards of $3500. Also I already looked at the guide for the 4l60e and did not find this. Please help.
Sent from my XT1585 using Tapatalk
