98 K1500 5.7L has low compression on one cylinder. 110 across the board dry, except #5 is 85 dry and 105 wet. Should this be enough drop to give noticeable performance issues? Rough Idle and Low RPM performance, fine at top end. Have decarboned intake, replace plugs, wires, cap and rotor. Decarboned IAC. Check engine showing random misfire and left bank O2, or on #5 side. Possibly IAC? If I unplug while at IDLE, no change. Ideas/Opinions?
