1 - 3 of 3 Posts
Hey everyone i need some info/ help
I have a 2002 Chevy 1500 z71 5.8l I just bought this truck.
The guy I bought it from tried to replace the brake lines himself and strips the Line nuts that go into the abs control module.
I picked up a used control module for the same year truck. And put it in my question did do I need to have the abs control module programmed to my truck or should it be plug and play kind of thing.
Thanks for the help In advance
I have a similar truck and have been reading up on doing the same thing you are. My ABS module is bad. I don't believe you will need to get the module reprogrammed but I'm pretty sure you will have to use a scan tool capable of activating the ABS unit to bleed all the air out of the system.
1 - 3 of 3 Posts
