If you plan on doing ANYTHING more than just turning off AFM, in regard to powertrain modifications, I would highly recommend you purchase your tuner from either a local shop that can give you custom tunes as you add on, or from someone like Lew at Diablew.com. Otherwise, you will have your tuner, and you will be able to load the "custom" tunes that are loaded on it, and adjust certain parameters, but if you start getting into long tubes, cat delete, cam, etc. you're going to need a custom tune. The handheld won't be able to adjust for things like that.
