1 - 5 of 5 Posts
I have a 2002 2500HD with a 8.1 and an Allison transmission. The first problem I noticed was that when I shifted it into gear, (forward or reverse) the dash indicator only flashed behind the letter, (D or R). Now when I shift it into 'R', there is no movement and only 3rd or 4th gear when shifting it into 'D'. Any suggestions?
How's the fluid look?
The Allison has a separate computer on it, so you'll need some fancy scan tool too read it. Typically, a problem with the Allison won't even generate a CEL. Check for codes... my hunch is that it's electrical (unless the fluid is nasty).
These transmissions are fairly bullet proof behind the 8.1 and 99 percent of the time the problem you describe is caused by a bad neutral start switch which is located on the outside of the trans where the shift cable attaches.
Thanks for the suggestion guys. I had the transmission serviced about a year ago and the fluid is still nice and red. I will check the NSS and see if that is the problem.
1 - 5 of 5 Posts
