I've put amber lights behind the grille of ALL trucks I've had....U hafta remove the grille to make the install
so much easier....just be sure to mark JUST where you want them B4 removing it so you won't end up
with some lights directly behind a cross piece of the grille itself. Biggest thing, in order to save time after
removing the grille is to locate the EXACT parking light wire you need to attach to B4 removing it.
I always use the type of connectors that have the thin solder pice inside of it, then use a lighter to heat
the solder up, and also the ends of the connector to grip tight to the wire...AND...before doing that, slide
on a short piece of heat shrink tubing to ENSURE a GOOD connection to avoid getting rain inside it!
I have NOT done this yet to my '19 Silverado, as I got it Dec. 10, and haven't taken time to buy the
amber lights. BE CAREFUL removing the grille....you do NOT want to break any of the PLASTIC!!
I'm lucky, never broke anything....YET!!
