Hi There,
I've seen other posters with this problem, unfortunately I have not found posts where people have posted what the problem was.
I have put two new and one used impact sensor onto my 2006 1500hd 6.0L Sierra, nothing clears the code, my mechanic has put his scanner on my OBD port trying to help clear the code. I know that typically just putting a new sensor on should clear the code when it does it's self-check at each start. The two new sensors were from Dorman and the used one was from the junkyard has a perfect match for the code on the sticker (the Dorman one doesn't)
I have checked the connection at the sensor for corrosion, I've pulled the panel by the hood latch and checked the connection for the airbag system there, I have looked at the module under the drivers seat and tugged on the wires there. I cleaned three locations where I have found grounding wires (two under the truck under the footwell, and one on the front bumper area). Nothing has helped.
I would really appreciate hearing from someone who has managed to clear this B0103 code and any other ideas people might have for me to check out.
Thanks In Advance,
Cory
Thanks In Advance,
Cory
