So the the truck is a 2013 1500 with the 5.3. It has long tube headers and a whipple supercharger on 8 pounds the truck was dyno tuned and ran great for about a year.
Recently it will backfire about 4 or 5 times in a row and you can feel the truck stumbling. It only seems to do it when I accelerate enough to get the truck to downshift. If i back off the throttle it will stop as soon as I do but if i continue it will continue to stumble backfire half a dozen times or so then it will take off and drive normal. Just after it does this the check engine light will flash a couple times then turn off. Other than that it runs fine and there are no idle or starting issues at all.
my handheld won't read the code because the light turns off.
Also one day I revved the truck when it was parked and stood near the exhaust, when I did so I could see some black smoke coming from the exhaust, not a ton or a huge cloud but enough of a hazing where I could see it.
The air filter is clean and I didn't have a ton of time the other day so I pulled one plug out, the one i pulled looked fine but I didn't have enough time to check them all.
Any comments or ideas are welcome and thanks in advance
