My 2001 sierra 2500 hd has a couple of electrical issues: One, the tachometer only works when the brake pedal is pressed, leading me to think a bad ground is the culprit. Two, the fuel gauge is intermittent, and also SOMETIMES changes when the brake pedal is pressed. Do you guys have a suggestion on where I should look FIRST? I don't want to go through the entire system if somebody else has had luck with checking the _______? Thanks for any help
