Hey everyone, looking for some help in an SOS kind of fashion.
Short Backstory: last October I replaced all 6 cab mounts on my 4x4 04 silverado 1500 Z71. I forgot to disconnect my battery and fried the BMC when welding on the new mounts.
Following this incident I replaced the BCM with a reman. It ran fine for a week then went bad again. I figured it was a fluke so I had the shop send me a replacement. This new one went in fine but went into security shutdown so had to so to the dealership to have it cleared. This was six months ago. Since then it’s been completely fine and have had no symptoms or lights on the dash whatsoever.
That is until this afternoon when I went to leave work. (I’ve been having trouble with connection from terminals to posts on the battery due to corrosion.) I get in my truck and have no power so I get out, loosen hot wire bolt to relieve pressure on the posts, rub the terminal against the post a little and tighten it back up and it restores power asper usual. Except this time, all symptoms of my shot BCM have returned. (No power to windows or locks, no dome lights, constant power to the reverse camera(should only have power in reverse) and truck starts and immediately dies)
I’m at a loss as to what might be happening here. Obviously something is causing the BCM to fail but I have no clue where to even start diagnosing that because as I said I have no other symptoms or lights whatsoever.
Any and all help is appreciated!
