My front brakes seem to lock up a bit when I'm driving. I know because the brake pedal gets stiff and truck runs at higher rpms cruising at 60 mph. Replaced the whole front end assembly down to the 3 bolt triangle shaped hub deal. Still does the same thing so I unplugged the abs sensors underneath the wheel wells but that wasn't much help. I also know they lock up cause the wheels get extremely hot. Once came to a point where the chrome around the lug cap started to shrivel and wrinkle from the heat. I'm assuming maybe it's a computer malfunction or maybe I haven't bled it right. I don't know at this point. You're help is greatly appreciated. I apologize for any misspelling.
