I just copied this from an eariler post i had....
I just did mine. '05 silverado 5.3 front and rear studs on the drivers side broken. First I PB Blasted the manifold to y-pipe bolts,waited about 10 min. (dis-connected the battery) then heated them till they started to get red. 1/2 inch impact for the accessable two, breaker bar with jointed extention for the PITA one(removed upstream O2 sensor for access) once those were off, i pulled off the spark plug wires(broke one ) removed the steering shaft bolt and let it lay on the frame. Loosened the unbroken bolts pretty easily with a ratchet and removed with air ratchet. Removed manifold from the engine comp. to workbench. pulled out the heat shield bolts and cleaned up the mounting surface.
Now for the broken studs.... I was lucky cause only the head was broke off, which left a little less than 1/2in of bolt sticking out from the head. Got a good set of vise-grips, and clamped them on as hard as i could. The front one came out very easy, the rear was a little more stubborn. then cleaned the head with mesh sand paper.
Put new manifold to y-pipe gasket on and set the manifold back in place. put on new manifold gasket on and lined up two starter bolts (m8-1,25x30mm). Put anit-sieze on and hand started all the bolts. tightened them all down, then under the truck i went.... once everything was tightened up, i put the heat shield back on with new bolts (m6-1,0x10mm) and over-sized washers. Replaced all the spark plug wires with new ones(AC Delco), reconnected the steering and battery. Started her up and she purred . Check engine light was out and I'm a happy guy. took about two hours plus clean up time. did the passengers side, almost same as drivers side, except all the manifold to y-pipe bolts are accessible without removing the O2 sensor. The oil dipstick tube runs thru the manifold and needs to be removed.
Dipstick tube broke trying to remove it :-x . Got it out by removing the starter and heating around it. No one had it in stock, so I cut off the jagged ends and used a 3/8 compression coupling as a temporary fix. Truck is all back together and running quiet
Also note that the y-pipe connection gaskets are different, drivers side has a round crush washer and the passenger side has a donut gasket.
I looked at my wife's 08 Tahoe and it appears that the process would be the same on the newer trucks.
I got Fel-pro gaskets and the metric bolts from Advance Auto.
