I had cylinder 7 Lifter go bad on my 2016, my mechanic pal at Fearless MS here in HAWAII noticed the lifter was stuck in the block when he disassembled the top end. I decided to go with a new block in case the cam was shot as well and possibly more bottom side damage. He did an engine swap from a 2017 wreck with new lifters timing chain, and machined the heads. On fire up it ran great. I was still getting some heavy bubbling out of the bottom coolant hose from the expansion bottle to the water pump at idle, so we replaced water pump and tensioner. Its been a week out and I've ran about 1500 miles the temp at 210 no overage and oil pressure soild. It will still bubble at Idle only after a long run. It's aggressive Bubbling into the expansion bottle that makes a clacking sound audible in the cab, but not every time. Anyone get some idea if it's still burping out or do I have a problem.... hahaha
ps any major differences in the 2016/2017 engines so when I buy parts?
Sent from my SM-G975U using Tapatalk
