Can I have 15" rims on my 13 1500?
742 views 7 replies 3 participants last post by  ferraiolo1
Getting a lift and new shoes and all the fixin's. I really like the look of 15" rims on a nice set of offroad tires. Can I actually fit 15" rims on my truck?
Tire Wheel Backspacing Offset
285/65 R18 Factory 18 - -
305/65 R18 18x9 - +12 to +18mm
295/60 R20 Factory 20 - -
305/55 R20 20x9 - +12 to +18mm
Factory 18in & 20in wheels can be run but require 1/4in wheel spacers with 295 tires
Models equipped with Factory 18-inch or larger wheels must run 18-inch or larger wheels if changing to aftermarket wheels.
Always consult the lift manufacture to determine what wheels you can run. And with a 4.3 and a 6in lift youre going to be slowwwww
Rough country says I need 18" wheels or larger with that lift. I didn't know if there was any way I could fit 15" rims, so I just wanted to ask on here to make sure since I really like the look of 15" rims. And I only plan on getting 33" tires, so I don't think that'll affect my speed TOO much. I don't know, maybe I'll just get a 4" lift instead. Tough decisions lol
if you already contacted RC in your older thread then why make this one when you already had your answer?
The wheel options will be the same for a real 4in lift as well. If you want to stick with normal offset 17s then just buy a leveling kit and 33s. Or the rough country 3.75in combo lift. NOT the 4.75in combo lift or the 3.5in lift.
