I am sure GM has it's reasons but for someone that isn't all that familiar with modern vehicles, can someone explain a couple of questions.
1. Why does my truck have two battery trays?
2. Why if it has two, does GM decide to use the one in the rear of the engine compartment on the passenger side, underneath the support brace instead of the one on the drivers side in the front of the engine compartment which is very easily accessible?
Be kind with your responses. I just spent twenty minutes trying to figure out how to get the fuse box cover back on after I opened it to see what the heck was under that black cover with a picture of battery stamped on it....I was thinking "THREE battery trays"? Anyway, I finally figured out you have to open it up in the front, then back, and to replace the cover, you latch the front and then the back. Another couple minutes of messing with that and I was close to getting out the rubber mallet.
So, what is the deal with the two battery compartments and why use the one stuck way up under in the back?
Or is this just another one of those GM engineering WTH issues?
