Ah I didn't know abt the prep work or to not be able to on fading paint. But ceramic will help from the sun making it fade and peel?If you have scratches, etc., you'll need to do a full paint correction first (clay bar, cutting [and maybe wet sanding], polishing, waxing). Ceramic will help protect the paint but it won't fix or hide imperfections. If your paint is starting to fade/peel, you'll need a repaint.
I didn't know about the cold weather situation. What wax do you use? I've never had a nice vehicleThere are many out there for a Diy cquartz is the way to go, it claims to harden your paint and help prevent minor scratches. Take that for what it’s worth I would say at best very very light protection and anything diy won’t be the same as a true pro dealer can get. As the post said above you need to do a full prep work. They make a speical soap to use when washing clay, polish etc. anything not corrected or left pre coat will not only still be there but will be “covered” also not sure your area most coats don’t flash to well in the cold. I was going to do one myslef just going to wait till spring. For now I’ll use a sealant and wax and let it Rock for now
Damn I didn't know that. UnderstoodAs red sled said if your paint is already fading or peeling it’s too late . Ceramic is great especially if you do it befor paint accumulates scratches and such .a lot of prep work plus you have to use the right kind c quartz is trusted there are others . There is also graphine coatings now that are really competitive . Two things I recently did mine took 5 hours of light prep work since paint was in great condition you have to remove all prior waxes sealants such than no imperfections or it will look likesecond it will have to sit and not get wet for at least 24 I waited 48 hours for the coating to cure one last thing the towels and applicator you used will have to be thrown away since when coating cures it leaves behind shards of glass in them but sealants waxes are good plus chemical guys makes hyrdrocharge which is right on par
Yeah, like these products? That's what you're talking about?Yup I just picked up a new 23, I was going to put a ceramic coat on myself, but it is cold here prob won't get much higher than 32 rest of the year, my game plan now is going to wash, clay, light polish or a finish polish/ sealant and a type of wax over top. The new rave of products are "Si02" which is a form of ceramic coating. Just be mindful that most of these Si02 I won't say there are full gimmicks but they will not last as long as a true coat or a prof coat. There are very few out there but I have a si02 past wax from I believe Mckees, and I think another company just came out with one as well could be adams or another brand. The real trick part that should be left up to the pros is the paint correction, I have a hand polisher that won't do any harm I played it safe, but if you get one that can truly "cut" you need to be very careful as you could burn through the clear coat.
Man I've got a garage, but I can't fit a bone stock 06 extended cab 1500 Silverado. It's pathetic lolIt’s cool just like anything else you get out what you put in had to do mine at the firehouse since I don’t have a garage ……..yet![]()
What leveled17yeti said could have been said better. You need a perfect surface before you apply a coating otherwise it will look like turd for a long time. You can see here the results of the glass like finish if you take your time. And like Leveled17 said, toss the applicator out at the end of each session because it will scratch the hell out of the surface if you try to reuse it.Yeah, like these products? That's what you're talking about?
Premium Car Wax Sprays & DIY Car Detailing Supplies - Torque Detail
Get the best car wax sprays, ceramic coatings and DIY car detailing products - manufactured in the USA by professional detailers for car enthusiasts and everyday drivers alike. Our easy to use detailing products will give your vehicle the same high gloss shine and lasting top coat protection at...www.torquedetail.com
Sent from my Pixel 4 XL using Tapatalk
Damn that truck looks like a mirror. I'm jealous of your garage size lolWhat leveled17yeti said could have been said better. You need a perfect surface before you apply a coating otherwise it will look like turd for a long time. You can see here the results of the glass like finish if you take your time. And like Leveled17 said, toss the applicator out at the end of each session because it will scratch the hell out of the surface if you try to reuse it.
In this pic I did the drivers side and had not done the tailgate yet.
Ok cool I'll check em outYes it will enhance the color. Blacks look blacker, reds more red, etc. It’s liquid quartz which reflects light.
It’ll still get scratched and mud will still stick. But the work needed to clean and correct that is no where near than before.
Apex Detail on YT has demonstrated all of this many times
Lol that crap is said. I'm like what's the point of a garage if you only make em big enough for dudes who use pronouns to park their car..Better than mine I can fit our old sad 07 yarus I there 🥲
