I’m having an issue with a chemical smell inside my truck for about a month now. Makes nose burn, an eyes burn and water.
It usually happens after sitting in the heat. It goes away after you let it air out but comes back when you come to a stop with the a/c on. A/c still blows cold so I do suspect any leaks. I’ve replaced the cabin air filter. I’ve read in other forums where it could be a leaking heater core and then vaporizing inside cab, pressure tested cooling system and no leaks were found. I’ve aired out the truck when it’s parked, it helps but not a permanent solution. Placed baking soda inside cab to try and absorb some of it for a couple weeks, didn’t work.
I’ve read a couple other forum post from awhile back but no solutions were posted. Any help is greatly appreciated!
