1 - 4 of 4 Posts
2012 Silverado 1500 work trim
Hi fellas. I’m new to Chevy’s. I’ve got a 2012 Silverado 1500 work trim. It’s got the roll up windows, and none power locks. It was a highway vehicle I got at auction.
I need to hardwire My radar detector, a backup camera mirror, and a usb socket.
i’m reading I can use the pins in the mbec by the brake pedal. This is a picture of mine.
Automotive tire Black Bumper Font Motor vehicle
Can I use the diagrams I see people posting like this one?
Rectangle Slope Font Parallel Screenshot
And can I power 3 devices from there, the radar, the backup camera mirror, and a 12v usb socket?
Do I need relays or anything for that kind of power?
thanks guys.
2011 Chevy Silverado LT Z71 1500 5.3 ECSB
Yes, you can get power and ground from the MBEC.
Light Electrical wiring Cable Audio equipment Auto part
2001 GMC Sierra 2500HD CCSB
Take a look at this thread here, it has tons of info about MBEC.
Discussion Starter · #4 · (Edited)
Thanks for the replies guys.
I'm still not quite sure of how I go about doing this though.
I'm currently getting over the covid virus, and I am not at all with it physically or mentally right now.
PIN 1 is ground, I understand that. So I want to also use PIN 7, which is RUN/CRANK is that correct?
According to that MBEC page, PIN 7 is good for 10 amps.
That should be ok I think for my radar detector, and backup camera mirror, but wouldn't the USB socket be too much than 10amps? Does that mean I need to use PIN 8, and a relay instead of pin7?
If pin 7 can run the radar, backup mirror, and usb socket, would I simply put an inline fuse connected directly to 7, and then run the 3 devices wires to that inline fuse, and to the ground?
Or do I use pin 7 & 1 for radar detector, and backup mirror, and for my USB socket PIN 5 which is CONSTANT? My USB socket does have a power on/off switch.
When I tap into that reverse wire for my backup mirror's camera, I connect all the grounds together to pin 1, correct?
If anyone can answer these questions for me, I'd appreciate it.
Thank you
1 - 4 of 4 Posts
