I wanted to check on opinions and other options on a couple of wiring mods that I want to do on my 2014 Silverado LT CC. I am interested in adding both a tailgate brake light/turn signal bar and some lighting for under a bedcover. I would like to do this without having to splice into or cut any OEM wiring so I can remove if i need or want to. To power tailgate light strip I was going to get one of the T-adaptors (to go between factory harness and back of existing 7 pin plug on bumper) that would provide an additional 4 way flat plug for the light strip. I would rather not use the existing 4 way flat on bumper to power the strip. Then I would get constant power for the led lights under cover by spicing into the constant hot on the added t-adaptor (not original harness). Since it claims to leave full function of 7 way one of the wires must remain hot since I have tested and have a hot wire now without having to have key on. I am going to use 2 strips of lights mounted on underside of cover with a switch. The light that comes with the top is just not nearly enough. Don't think I need any additional fuses since everything is already fused. Any thoughts or concerns on this method? Any other suggestions to achieve same end result?
