So i decided to tackle this today. Only took me about an hour to do the whole process. Do this at your own risk. Make sure your truck is is already wired up and that the switch for the heated mirrors gives power to the rear on too. My truck is a 2011 silverado 1500 crew cab. First of all, you will need to get a new window that is heated. Since i own an auto glass shop i have easy access to those. Before doing anything i checked and found out my truck came pre-wired for rear defroster. Connectors are located on both sides hidden behind the plastic where the back seatbelt runs from. Wiring is about half way down kinda tied together with a bunch of other wiring. It had a rubber connector that looked like it was connected to something but it wasnt. Easiest way of doing this is to remove the seats and completely remove the side plastic panels. I did not do that (too much work) all i did was unscrew a screw and pull the plastic away. You will need a flashlight to see anything. It is a plug and play kind of thing. My truck comes with heated side mirrors and the back defroster runs off the same switch. Below is some pictures of the process. I tested it and it works so far. Hope with helps!
