Cruise control not working
6.4K views 7 replies 5 participants last post by  Z15
Howdy!
My truck is a 1992 k1500 SLE 5.7L 350Ci V8 4-Spd Auto with the Z71 offroad package.
The problem I'm having is that my cruise control will not work. No lights for cruise control come on in the dash, and nothing happens when I press the little button way at the end of the instrument stick or move the switch right near it.
Any ideas of what could be wrong?
Thanks!
~Kenmathis
If im not mistaken, there's no light in the dash on that truck, but I can tell you that the multi function lever assembly is most likely the culprit. If you're speedometer is working, check the brake switch for proper function. After that as long as you have power where it should be you'll likely find the tiny wires to the switch are broken inside the column (from tilting the wheel up and down over the years) or the switch in the lever has simply failed. It's actually very common.
Sent from Paul's phone using Tap Talk
Where would the brake switch be?
