What is a worthwhile coolant to put into these duramaxes? I've heard a lot about the dex cool problems but not sure if they fixed it yet. I believe that is what is in my 2012.
The gm/Acdelco stuff is orange as well.The factory fill stuff is sometimes orange or sometimes has a pinkish tint to it.I though for awhile it turned pink when it broke down but I have seen brand new trucks with the pink.I dont know why.Gozzie said:Prestone has a newer Gm approved dex. It's orange and not red. Can be mixed with red if needed. It's a little more expensive.
That's what I'm running but I'm not in a duramax either.
Cooling systems are not sealed. There will be losses thru the pressure cap and can be enough to trip the sensor if not topped up every couple of years. This especially happens when cold weather arrives.Sierraluva said:.....have recently had the "low coolant, add coolant'' light come on. I have no leaks that I can see. I'm hoping it's not head gaskets. 99k miles on a 2012.
I agree - if your lucky / just low and not leakingGR2017 said:Cooling systems are not sealed. There will be losses thru the pressure cap and can be enough to trip the sensor if not topped up every couple of years. This especially happens when cold weather arrives.Sierraluva said:.....have recently had the "low coolant, add coolant'' light come on. I have no leaks that I can see. I'm hoping it's not head gaskets. 99k miles on a 2012.
