I looked through other topics before this post but did not see anything that would answer beyond what I have already called myself attempting
2002 Silverado 2500hd ext cab. Passenger window works from driver and passenger controls, but the driver window does not.
Ive replaced the switch, regulator and motor.
Checked the harness in the door jamb and found one broken wire that i repaired last night and the window worked, this afternoon i went for a test drive and the window is not working again.
Thinking my 'fixed' wire was the culprit, I cut out the part i fixed prior and repaired it again being sure i had solid connectivity.
Im still not getting power at the driver window, but locks, and heated seat controls and passenger window control works, mirror is not but I have a new switch on order for that.
I checked for other broken wires in the harness, and called myself checking fuses, Im at a loss here...Any ideas on what i could do or should do?
