2007 Chevy Silverado Classic crew cab two wheel drive Duramax .
I accidentally left the driver's window Cracked and it rained and some water got inside the truck on the door panel. Now the window won't roll up door won't unlock and the mirror can't be adjusted from the driver's control panel. Checked all the fuses pulled the circuit breaker pulled the panel apart and the switch assembly but can't find a solution. Even disconnected the battery. I don't want to start throwing Parts at it if somebody might know a simple solution. Next I'm going to see if voltage is getting to the switch panel. Any suggestions?
