I know this forum is for Silverado/Sierra, but I just came into possession of an '03 Tahoe (5.3, loaded, leather, Bose stereo, etc.) for $1k. Y'all have helped a lot when I had questions about my Silverado, so I figured what the heck, I'll see if anyone might know about this.
The Tahoe runs and drives great but it has a draw draining the battery. Initially I didn't care because I had just planned on using its powertrain for my Model T, but now my wife wants me to let our son drive it. I'm fine with that, I can get another LS engine anywhere. However, this now leaves me with the electrical draw issue.
I'm planning on using my multimeter hooked up in series with the negative battery terminal and pulling fuses until the draw goes away in order to locate the circuit. However, this leaves me with two issues. First, the Tahoe doesn't have a "door open" button that I can tell, so how do I make the truck think the drivers door is closed while I'm pulling fuses from the panel on the left side of the dash?
Second, after Googling this issue, I've seen a lot of stuff come up regarding the BCM. If I don't pinpoint the issue by pulling fuses and it ends up being the BCM, what am I looking at in the way of hurdles when it comes to replacing that? I found BCM's for around $150-$200, but once I get one, do I need to have it programmed by a dealer, or is that something I could order pre-programmed?
Thank you all for your insight and assistance. I look forward to your replies.
