Morning all
Out of the blue driving to work, my 2010 2500HD tells me 'ENGINE HOT, A/C TURNED OFF'. The water temp gauge is stuck at the lowest reading as if it's not working. I checked under the hood and the engine isn't any hotter than normal.
Driving home from work, same issue but then the engine warning light came on! I pulled over again, and all seems well under the hood, so I carried on home.
The coolant level was a little low, but nowhere near the lowest level so I topped it up. I then disconnected the battery for 10 mins and the problem seems to have gone away, although I haven't had time to drive it yet to see if the water temp gauge is back to normal.
I've had a look around the forum but can't find the exact same symptoms. Has anyone had this problem before?
Many thanks
Rob
Many thanks
Rob
